Turning of asus OC
1 Sep 2007
St. Helens & Blackpool
Hello, so i was messing round with some buttons in the Asus Ai suit and used the Auto Tuning button. Its Overclocked my system nicely but i'm not bothered about OC'ing as it is of no benefit to me, so now i want to disable it.
I cant find a button in the software to revert back or disable the Ai tuning. I have an Asus p8p67 pro Motherboard.
Does anyone know how to remove this OC.
I've tried Uninstalling the software but no joy.
I've not a clue with the bios, (stupid fangled mouse click thing). Was hoping someone in the know could help.
just set optimized defaults in the bios,it will say at the bottom of bios page,then turn off intel turbo boost in bios,than it wont auto oc at all,as for ai suite no idea it should just un install
Also be careful using the auto OC options in AI Suite. I messed with it an asked for 'extreme' and got 50x104 @ 1.6v!
Go into the BIOS settings, go to the CPU options and disable the Asus OC from there.
Thanks guys, sorted, now sitting at stock speed :)
This was something that was worrying me, the only overclocking i ever did was manually in a bios. so was worried that the software may have gone overboard with some settings .
