- 10 Jun 2010
- Scotland
I need a hand lads!
I have a system which I had an HD3870 installed in. I took it out to use the onboard graphics as it has HDMI out and I wanted to connect it to the TV.
Anyway. It wont boot. This is of course due to a driver issue with the card.
It POSTS fine and all is well until the Windows animation which it then restarts afterwards.
I've tried:
Reset CMOS
Safe mode
Last known good configuration
Low resolution 640x480 mode
attempted a startup repair using windows 7 console thingy
There is surely a way of getting this to work without a reinstall of Windows?... surely to god!
I suppose I could connect the HD3870 back into it and then install the graphics for the onboard? Then remove the card again? What do you think?
Simpler way?
I've tried:
Reset CMOS
Safe mode
Simpler way?
