I'd do that aswell but only had a 60gb and 9gb left, have some games on it but dont think bf3 would fit.
To free up space on your SSD
Disable Hibernate
NOTE: This option will disable hibernation, delete the hiberfil.sys file, and remove the Allow hybrid sleep and Hibernate after Power Options under Sleep.
1. Open a Elevated Command Prompt.
2. In the elevated command prompt, type powercfg -h off and press Enter.
Move your page file to another hard drive.
To change page file settings in Windows 7:
In the Start Menu search box, type "Advanced System Settings" and choose the Control Panel applet that should show up, "View advanced system settings"
Under "Advanced" tab, "Performance" section, click "Settings..."
Under "Advanced" tab, "Virtual Memory" section, click "Change..."
These are the actual settings. Uncheck "Automatically manage paging file size for all drives" and you can change these settings. Highlight the drive you want it on, and select either a fixed size or system managed size, and then click "Set". YOU HAVE TO CLICK THE SET BUTTON. Do the same to remove it from the drive you don't want it on. ("No paging file".)
Click OK, and you should be prompted for a reboot.
