Dead PC has everyone baffled, help?
15 Jan 2012
Hi!
Have a Packard Bell Imedia x2424 (I know! I didn't know any better at the time *shame*) that has died and myself and my technically minded friends and at a loss as to what the problem is.
I want to build myself a new PC anyway but if I could fix it and give it to my Mum it would make a big difference to her, so i'm hoping someone can help a gal out. It's a long old journey to this point (and sorry for the long post) so i'll try and keep it short with bulletpoints, if you need elaboration, i'll do my best. :)
Specs; Everything standard except a Radeon ATI graphics card I put in.
MCP73VT-pm motherboard
q6600 CPU
4g RAM
250w PSU
WD Caviar Blue HDD 640g (and an old 60g barracuda drive I put in there)
I think that about covers all the important bits...
SO here's what's happened so far...
  • The PC starts crashing.
  • Starts to shut back down within 3 seconds of turning on, no beep, just fans for a few seconds then dies
  • Took everything out and tried installing one at a time, just motherboard power in and it turns on and stays on but no beep or signal to screen so we figure it's mobo or cpu fried
  • Add 4pin cpu power and machine returns to shutting down after 3 seconds
  • Replace BIOS battery - On/off time is now 1 sec instead of 3 :s
  • Two friends who know a lot more than me both try all reseating etc with same results
  • Take PC to professional because I need some important files from HDD, he takes one look and sais that mobo fried from trying to run GPU with crappy power supply, suprised it lasted a year, get new mobo and PSU, you'll be fine...
  • Friend gave me old foxconn mobo with cpu to try, 755 socket, just like the old one. Try swapping CPU's, no change. So put new mobo and CPU in. Turns on and stays on, now with clicking whirring sounds I think are HDD, but still no beep or signal to the screen
We're all completely bewildered by what this could be, would really appreciate some help!
Wow, quick response guys cheers :)
Forgot to add, tried new mobo with GPU in and out... and tried spare PSU from old PC which is 350w.. If that makes any difference
Its the CPU then... I am assuming
you have tried it with the HD and CD disconnected (and associated cables)
with one stick of ram (i assume you have 2)
You are not shorting out the board my testing it on a metal conductive box
you tried just shorting the power on pins incase the power switch is stuck on (never seen it happen)
there are no other common factors you are not telling us about (eg extra cards)
So with a new mobo/CPU and different CPU, sys turns on but does not display on screen and there is a clicking wirring sound.... sounds like a faulty HDD. If your drives are IDE, check the cable and make sure they are in the correct order according to their jumpers, if they are SATA, try a new drive, faulty hdd maybe preventing the mobo from posting.
Have you tried taking everything out of the case and trying to get the motherboard to post with the minimum ammount of things connected to it?
One stick of ram in the furthest slot away from the cpu, no gpu if the MB has on board graphics, no hard drive attached, after totally reseting the CMOS etc etc?
I just tried this on both the borrowed mobo and the original one. This time resetting the bios with the jumper as before I only took the battery out for a while and changed them....
Neither will post with just one stick of ram, main mobo and cpu power and connector to pc on button... I am guessing then that my original mobo is fried as suspected, and the one my friend gave me to test with just unfortunately happens to be buggered too?
It's just unfortunate I have no working machine to test these all the parts against (e.g. the spare psu) so I know it's not just those bits being broken...
