Socket 1155 - What Chipset Should I be looking For?
22 Dec 2009
Upper Skurt
Hi,
Would anyone please be able to advise me what chipset I should be looking for when getting a socket 1155 motherboard? I know that there are different chipsets but have no idea of the pros and cons between them.
The PC that the motherboard will go into will be probably have an i7 2600 CPU with 16gb of RAM running Windows 7 64 bit OS. It will be used for video editing and encoding, database/spreadsheet work and possibly some gaming.
Also, any recommendations for a suitable socket 1155 motherboard would be appreciated. I am not sure if there will be any overclocking in the system but it would probably be useful to have a motherboard that is capable of overclocking should it be required.
Rgds
Binty
Thx for the quick replies.
Are there different revisions/versions of the Z68 or are they all the same? Also, to keep compatability with legacy printers is there a version with a parallel I/O port?
Sorry for the noooby questions but I have very little knowledge of these matters and it is a bit of a minefield for me.
Binty
Z68 is indeed the way to go. It allows overclocking and onboard graphics, as well as a few other bits.
I haven't seen a single motherboard from the past 3 years with a parallel port I'm afraid.
OK, thx, parallel card or USB to parallel printer it will have to be then.
The ASRock Z68 boards seem to get good feedback, I will have a look at those, is there any particular variant of the ASRock Z68 that is favoured or will any of them meet my requirements?
Binty
I couldn't find any 2.0 Rev GA-Z68AP-D3 on the list of approved supplier my university uses. So I plumped for the GA-Z68P-DS3
I have built so many DS3's on older chipsets that it seems like destiny.
Why did you need a Parallllllllel Port? [EDIT] Ah yes for printers. You might get away with adaptors - but for surety go with onboard.
Good luck.
