Of course, it's quite a quick little PC more than capable of running those things.
And it is an AMD ?!
hi Bigsy
am i right in thinking that the case came with 6 heat pipes, but you only installed 2 because of the layout?
if so is it not possible to bend the pipes? to install more?
The case only comes with with 2 heatpipes, the heatsink and case has room for more simply to aid fitting on different mobos.
As is the mobo heatsink would make it difficult to fit more, I think they would fit but it would be marginal. Still two is absolutely fine, surprisingly.
I'm afraid I don't have anything in situ for comparison. I now added a bdrom and usb dac/amp which I mounted internally, it does everything as a stand alone box.Can I be cheeky and ask for a pic in situ? I want to see it's size relative to a disc player and/or AV amp if you can oblige.
cheers!
Picture quality in w7 media centre seems far lower than with the addon Geforce 210 that he has?
I'll try the latest drivers when I go back up there! Power consumption is low, not as good as yours but he has a 400w corsair psu, 3xhdd and a dual freesat hd card so I guess I couldn't really expect to get anywhere near. Psu efficiency at low watts doesn't help
