Get a Mustang, apart from the fuel you'll find it veyr cheap to run. Massively undertuned simple engines means nothing ever goes wrong and when it does, it's cheap as chips to fix.
You don't see many either and they have 4 useable seats.
Plenty of room in the back!
They don't break, when they do they cost peanuts and any monkey can fix them, afterall I did so much on mine myself in the drive. Such jobs were supercharger fitment, intake manifolds, plugs, injectors, air intakes, all rear suspension, some front suspension, brakes. Was all easy!
What I had garages do, mainly Powerstation as needed a ramp was:-
Shocks and absorbers, springs.
Ball joints (uprated ones)
GEO setup
Uprated fuel pump
Exhaust Headers / Manifolds!
