- 17 Sep 2011
- In my PC
Hi,sorry to be a pain in the butt but im having bother figuring out what settings i should use in the BIOS of my ASUS P8Z68-V motherboard to keep my i5 2500K at stock speeds and running as cool as possable.
I want all voltages to be default or lower if possable as im having trouble when running intelburntest. Before the first run finish's 2 cores of the CPU get up to 74c and i have to stop the test as this is over intels stated safe limit of 72c and OCUK's recommended limit of 70c.
Im using the stock cooler that came with the CPU and it seems to be seated properly and solidly onto the CPU.
I have the CPU voltage set to 1.19v and the speed is 1.6Ghz idle and 3.7Ghz when stress testing. During the burn test it dips down to 1.176v wich i have read elsewhere is lower than stock voltage but im still getting these high temps. Is it just "normal" because its on the stock cooler?
If anyone has any suggestions as to what settings i should use in the BIOS then please let me know,especialy if you have personal experience with this board and CPU,cheers!
