But full cover looks better, and when spending so much on graphics cards, why skimp on looks?!
Not everyone has a pansy windowed case![]()
My thought exactly! My tower will sit under my table.
This is going to be expensive
2 x 7970
2 x 7970 Blocks
2 x Backplate
1 x Crossfire Spacer
1100 quid![]()
With the core only blocks they are a nightmare to watercool multi gpu systems as iam planning to crossfire there a no go
Anyway pre-ordered a nickle acteal one and should get my 7970 ordered at the end off the week![]()
Because you buy it to play on it and not look at it?You can have £40 blocks which are universal and you can use them on pretty much any card.
Are them blocks not single slot ? look like there covering the bottem pci slot
#You can get single slot brackets
Not talking about the bracket i mean the actually block looks about 1.5 slots high
How much are them blocks and adapters on average ?
Since when does watercooling not "rely on air at some point".
Memory barely gets hot and barely needs cooling, that is a non issue, VRM's can depend, old type vrm's that are fairly inefficient and generate a lot of heat need serious cooling(5870) and the better digi ones or the newer more efficient ones tend to run a LOT cooler. Either way a very low speed fan that you can't hear is more than enough to deal with memory/vrm cooling.
