KFA2 GeForce GTX560Ti OverClocked White Edition PCI-Express Graphics Card
Permabanned
29 Dec 2011
does anyone know anything about this card.
im looking for a 560ti at the moment around £150.00
is it worth £155.00 which is what i can get it for or are there other 560ti cards that would be better.
yes that is the one. the review is strange in mentioning 560 only but they do say it is 560ti in the review.
I've just ordered one, so I'll let you know how it is when it arrives tomorrow.
Just need to sell / return under dsr the 6870 I bought a few days ago now.
Mine just arrived & it is the 560 Ti version with the white pcb.
Can't complain for £150+ delivery.
Liking this card, unique and great stock clock. Quick question, is it a big card? Got a 260gtx and is at the very limit of my case size length wise.
I returned my 560 Ti (see sig.) today due to a problem that apparently has been ongoing with this model for some time now. The card was crashing all the time giving the message "Driver stopped responding and has successfully recovered". This happened mostly when web browsing or when playing games that used a web browser to launch eg. BF3 and after trying loads of different drivers, disabling hardware acceleration in web browser, increasing voltages etc with no progress I decided that enough was enough. It's really dissapointing because this card was great when it worked and the extra 1GB vram came into use with BF3 (playing @ 1080p the game was eating up 16**Mb) but after reading that these problems were nothing new and nvidia were doing nothing about it I had no choice but to return it.
I need to wait 5 working days now for my refunded money to clear and I'll be spending my money on an AMD card instead.
http://forums.nvidia.com/index.php?showtopic=207666
http://forums.nvidia.com/index.php?showtopic=215267
Was this something you had from day 1, or did it appear over time?
So far, after 3 days anyway, I haven't had any driver crashes with the 290.53 drivers & the KFA2 card.
I had the same problems from day one but installed the beta drivers and its fine - also turned off GPU acceleration in firefox etc coz that seemed to mess it up - aswell as MSN, but so far so good not had an issue for abit now
It happened from day 1 but I didn't try the 290.53 drivers, the only beta driver I tried was the 290.36.
I have just looked on nvidia's download page and noticed this:-
Key Bug Fixes
Fixes some random instances of triangular artifacts when playing Battlefield 3 (fix is now enabled for GeForce 400 and 500 series GPUs).
Fixes a default panel resolution/ timing bug in 290.36.
I think this is the bug that was causing my card to crash lol. Now I can't decide if I should hold on to my money and wait for nvidia to verify that this problem has been fully fixed or take my chances with an AMD card... Decisions Decisions.
I had the exact same problem with my 560ti gigabyte card until they released a bios for it which (touch wood) I have never seen that problem again.
Very annoying to see "the display driver has stopped responding and has recovered"
I know from google searching that loads of people have had the same issues and sometimes it is bad memory/bad driver/enable hardware acceleration....etc etc
not had any problems myself yet. browsing has been fine using firefox and played a bit of left for dead 2 without any issues.
Anyone having problems with this card and battlefield 3. I am getting a crash to desktop nearly every game. There is no error message pop up but it says my connection has timed out.
try disabling upnp in your router settings. dnt think its a problem with your gfx card
