- 23 Nov 2009
- North Leicestershire
G500 at 1700Dpi for everything including desktop use
I've got my DeathAdder set to 500mhz polling, should I have it on 1000mhz, is there much difference?
It depends on your mouse. My mouse performs worse at 1000Hz than 500Hz but yours may be the other way. Try it out and do some tests see which works best.
If your cursor is jumping then either the computer has terrible video rendering or the mouse sensor is a crock of ****. I am currently using a 450 DPI mouse on a 1080 screen and there is no jumping. If there was I would be getting an RMA.
If you move the mouse fast,the cursor jumps, no?
If you mean the cursor moves from one side of the screen to the other without hitting EVERY pixel along the way then yes...on any mouse...on any DPI. That is how cursors work else your computer would require ridiculous amounts of video processing power to even barely use the desktop.
That has absolutely nothing to do with DPI. Methinks maybe you need to go and have a look at what DPI actually is. DPI =/= tracking speed no matter how much you seem to think it does.
