** Who wants to WIN some BitFenix Alchemy Multisleeved Cables **
I would love to use some White Bitfenix Alchemy extensions to enhance my pc.
im missing tinkering with my rig, would love to see what white cables would luck like in my silverstone white case. using white tubing. only missing white cables, hint hint. good luck guys ;)
Bit late dude :p
Never win though :(
On another related note, whens the round 2 of the cases going down?
Congrats to the lucky 3! :)
Look forward to hearing your thoughts on these!
And once again, nice give away kul1! :D
BitFenix are on fire with all these comp./give aways! :D :cool:
can you get Sata data extension cables does anyone know? I like the bitfenix braided sata data cables but they only come in one length of 30cm and its just a little to short for me
Many thanks Kul1 for picking me :)
Address and cable types/quantities sent to bitfenix support, 8 in total.
Will post up a review and give you a big mention in my build log within a week of them arriving.
Odd request I know but is it possable to get a few metres of the braid to do some other cables (pump, fan, usb, temp probes etc)
If not can you add a single CM-010-BX to my order and I'll strip it myself.
Just bought a load of these yesterday,
2x pcie extensions
1x 24 pin motherboard extension
1x 4 pin power extension
Arrived today and they are fab!! much better than the nzxt product
Yep, i ditched my nzxt extensions after getting a few of theese. Id love to see sata power cable extensions available. The rig in my post above will be fitted out entirely with blue bitfenix cables, unfortunately the standard sata power cable will still be visible. Unless of course i can reverse mount the hdd.
you could always try sleeving your own setter? I have just ordered some white sleeving with some heat shrink as well to cover up my tacky looking sata data cables, i was going to buy the bitfenix sata cables but at 30cm length its just to short to be able to re-route them. Never done it before so hopefully wont be to hard to cover up the plastic looking cable :)
its very easy mate, have a glance at my build log, i make some black and white ones :)
Gonna try reverse mounting the drive first. Psu is brand new so i dont want to void the warranty on it. I have a large selection of black sata cables in various lengths for a little bit of a change from too much blue.
Those cables look great panyan! am i right in saying its best to burn each end of the braid with a lighter to stop it from coming apart when pulling it over a cable? Think i got 2 metres of 10mm braid and 2 metres of 12.7mm heat shrink hopefully that should be ok never done it before so i thought instead of paying out for a sata cable i will try and make a shappy red one look half decent :)
