Um, a think about 3 years between launches might have had something to do with it.
what difference does that make? windows 7 runs better on the same hardware. vista was bloated and crawled performing the simplest tasks.
It's a perfectly fine OS. Anyone that says otherwise is an idiot.
Uhtred
What difference does it make?
Device drivers.
Vista's device drivers, especially graphics adapters, were exceptionally primitive in the first year. To the point that early Nvidia drivers were actually unstable and would quite frequently crash (and then automatically restart, mind you, thanks to innovations in Vista's kernel).
It was a combination of factors. Hardware of the day typically wasn't even dual-core. The average graphics card had just 128MB, which isn't really enough to properly run a desktop composition rendering system as what Vista pioneered for the first time in a mainstream OS. Software had issues with UAC. Device drivers were crap. In short, it was a up hill struggle. W7 benefited massively from the growing pains that Vista went through.
If you install Vista and W7 side by side, patch them and install all the latest drivers. Other than basic things like boot time, which yes W7 is far better, you'll really have to squint and search to find a performance difference between the two. If I had to put a figure on W7's overall performance gain, it would be around 5 to 10%. Which isn't really perceivable.
W7 is a better OS at the user level. I would not disagree. The only reason I haven't upgraded is that the benefits simply aren't great enough for me to justify a month of turmoil and reinstalling my apps.To be clear, I liked vista at the time and i did prefer it to XP as long as the machine was powerful enough.
I'm not saying it was a terrible OS as most people say, it had tons of improvements over XP, but I don't miss it in the slightest now W7 is here. On the same hardware my machine runs smoother than my vista sp2 build ever did, and it hasn't been rebuilt once. I don't care what you say, I do notice an improvement
I use it on my workstation since Feb 2007. Same install, never formatted.
W7 is fundamentally the same OS which benefited from newer hardware and better device drivers. Vista was ahead of its time, but suffered due to the age old "bad first impressions".
I would rather smear my wedding vegetables in fish paste and dangle them in a school of hungry piranha fish then have that utter piece of garbage in my house let alone on my machine.
Upgrade then?
Upgrade then?
Yes. Also prefer how multiple windows and tabs of Internet Explorer are previewed on taskbar against the single group everything together style of W7.
