BitFenix Shinobi Goes XL
One question,
Does the superchage USB port rely on a motherboard with a high amp USB header (Gigabyte 3X powered USB port for example)
No, it doesnt... We do have a own PCB in the chassis controlling the supercharge port! :) No matter what motherboard you are using it will work.
Ah, cool, so you just feed it a power connection from the PSU and make the relevant cable connection to the mobo?
Looks like a great case with some very nice improvements from the previous one! :)
I really like the idea for the hard drive cage (FlexCage) and as always the SofTouch treatment! :D
BitFenix Shinobi XL Full Tower Gaming Case - Black @ £139.99 inc VAT
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts. Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough.
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX
- 5.25” Drive Bays: x 5
- 3.5” Drive Bays: x 7
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)
- Cooling Bottom: 2 x 120mm (optional)
- PCI Slots: 9
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking
- Maximum CPU Cooler Height: 193mm
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)
- Maximum MB Tray Clearance (rear): 34.5mm
Only £139.99 inc VAT.
ORDER NOW
i could live in that case
anychance of them doing a shrunk version of the sqwiggly line case?
sorry i forget the name of it, but id like to see that in matx or even itx, would look rly cool :P
Uber case, definitely looks like it would suit all my needs! Someone buy one and review one ASAP so i can get an idea of what a real user thinks of it :)
@kul1 I knew it was going to be a Larger version of the Shinobi, Nice stuff! Loving the 2 x 230mm fans and 1 x 120mm fan, im betting this badboy cools like a real pro. Decent price too, well done to your chaps at Bitfenix
