So i now have my system as I wanted it and comes the part ive been looking forward to, watercooling it.
I am now looking at watercooling the NZXT Switch 810 going with the white one and wanting to go with black fittings and parts for watercooling.
I will be cooling an overclocked 2600k and an overclocked 7970, my question is if i get a 360 rad in the roof will that be sufficient ? and is it really worth going push/pull or will that not make a big enough difference ?
I did also ask in another thread about black blocks for cpu and gpu is there any reason NOT to go with those ?
I understand the plexi blocks can crack if you arent careful and im not really wanting that anyways and i had read somewhere before about a problem with nickel blocks. The black ones are ok tho ?
Thanks for any advice.
