As for the kind of music being recorded! It will 95% be live recordings with instruments including a drum kit, so the ability to record around 6 miss for the drunk kit would be ideal depending on price. Up until now, I have always recorded drums going into a mice, then having one out into the computer to record, not giving me any ability to mix the drums after recording...bit of a pain, but you do what you have to!
It seems the interface will be the most important piece of equipment! One with built in mixing capabilities would be great, but might be for a purchase down the line! Is it possible to have a good basic interface to start with, with the ability to cater to about 8 inputs, and then add a mixing desk to the equation later on? If so, will my monitors plug directly into the original interface? And also, if I did add a mixing desk a little later, how would that then connect? To the interface, or the mac?
Hi Detroit,
I would recommend the Presonus Firestudio for you.
http://www.presonus.com/products/detail.aspx?productid=5
8 XLR Inputs, 48v Phantom power (although no phase reversal), ADAT S/MUX for interfacing digitally with other devices and stable drivers.
I have owned/used a few of these interfaces over my time in various amateur/professional studios and it is a good buy.
As for the mixer situation - I used to 'sum' all my multi-track recordings into a large analogue mixer but I really don't see the point these days. Unless, of course you like to get 'hands-on' with mixing. Having said this, you might want to consider looking into control surfaces instead. A control surface is literally a controller for your favorite DAW that has faders, panpots, switches and usually transport controls. However, a control surface in NO WAY degrades your signal path or colours your recordings as no audio is physically routed through the device. It is simply a more elegant alternative to using a keyboard + mouse if this is what you are scared of.
We also need to remember that every time we convert a signal from digital to analogue or vice versa we are degrading it (same with adding EQ or ANY insert effect plug-ins for this matter). I moved from an analogue setup to an 'in the box' digital one with a controller in my studio and the sonic quality of my recordings is much improved. Unless you are planning on performing a multi-track recording say, of an orchestra, OR you really love phase reversal/manual EQ then a mixer will just complicate things. Remember, mixers look pretty and impressive when clients come into your studio but most, if not ALL the pros I know use a in the box solution centered around a decent audio interface and DAW of their choice.
In my studio for example, I have an Audient ASP008 8 channel preamp which is plugged (via ADAT) into my RME Fireface 800. This means that the signal only gets converted from analogue -> digital ONCE in the signal chain. Once it's in the computer its 1s and 0s even up until mastering + release.
Sorry if I've gone off on one but you get the idea. Mixers are only worthwhile if you have a lot of money to spend. If you are desperate for a mixer still, then look at the TLA M4, Audient Zen, Allen & Heath Zed series & Soundcraft live mixers. Remember also, that if you are working on a project and come back a week later to finish up there is NO way to instantly recall EQ settings (unless of course you want a digital mixer but then theres hardly any point - just get a control surface!!!).
Hope this helps.
