470 OC clocks and volts
7 Feb 2010
What have you managed to squeeze out of your 470?
1.025 @ 750/1500/1702
It's about 90% stable and never peeks over 65oC using the VF3000F... but I want more.
1.212 @ 875/1750/2180 which benches ok in Unigine. Although BF3 doesnt like it, so I put it on 850/1700/1800 for now, which works, but will see what max I can get for game stable.
Oh and never goes over 70c using Accelero Xtreme Plus :D
Have you tried OCCT to test for errors ? This brings errors up quite quickly if they exist
900MHz with slightly over 1.1v is stable on both of mine but I never run them above 800MHz on the reference cooler for general useage (~1.028v). 750Mhz is stable on stock voltage. 840MHz is highest I can get stable on reference cooler using the 1.087v limit.
I'm using the EVGA Precision overclocking tool but that's obviously restricted and my max voltage is 1.150.
What are most of you using?
Im using MSI Afterburner with modded Bios. Managed to get memory clock a bit higher now without crashing. I guess BF3 is good at finding errors :D
Sli gtx 470's. Ran daily at 750/1500/1674 on stock volts of 0.987. Had them at 800/1600/1700 on 1.012v, bench and game stable. Highest ive tried was 820/1640/1700, 1.087v afterburner limit for running the heaven bench. Reference cooled so dont like to run them much higher than 750mhz. Seen a few i7 9** users on here, blowing motherboard 24 pin atx sockets with theese cards in sli clocked high on 850w psu's, running a corsair hx 850 here.
