BT Infinity & FTTx Discussion
All installed and working :) BT test kit got 40mb down 2mb up. I can't seem to hit that on my box though (with overheads in mind), seem to bounce between 21 and 37.
Nice to see all the reports here - it's tipped me over the edge from 'give us control over interleaving and stop calling it fibre you lying ********!' to 'wow... that actually sounds really good'. Sadly, I'm still waiting.
My exchange has been enabled for 6months+ but my cabinet apparently not. I have read somewhere that Richmond council has been denying permission to BT to build them, and while I'm not in Richmond, my exchange is (Mortlake).
I've even started a spreadsheet with a graph! Showing the date I queried the db and the estimated time left. It only begins in November 2011, but from July onwards there was a pattern of ready in 2 weeks, 2 days before, expected date goes up 16days. Repeat.
https://docs.google.com/spreadsheet/ccc?key=0AmMvOoRhNBCEdDBNTG9nSnFlWm5GWlpiZkJrRU8tb2c
Fortunately my Be contract still has 2 months to go, so I'm not too bothered just yet.
Does the Modem and Hub HAVE to be installed at the master socket or can it be installed on an extension elsewhere in the house?
My current O2 ADSL+ Router is plugged into an extension in my family room. The master socket is in the hallway nowhere near any PCs and my partner would hate a bunch of kit being there :D
Modem must be at master socket. Home hub can be installed anywhere. They will provide a cable to link the hub and modem up to 10m I think.
I've looked at the Openreach rollout site, for an idea of a go live date for my exchange, which shows March this year. I also saw some Openreach engineers installing some fibre down the road. I asked to double check and yes it definately was fibre, so not long now!
But I'm in a block of flats at the moment, has anyone had any trouble with getting an install done to a flat? Presumably it would be fine.
Apparently my area is getting FTTP, which obviously isn't possible to a flat, but surely FTTC would be fine, as the copper isn't touched coming into the flats and I have a clear master socket.
Contractors have just installed a new FTTC cab near enough outside my house, how long is it usually from cab installation to being able to order? :)
I got the call too, I told the guy the current modem I have has had no issues but he said they need to replace it still since it wont be optimized for future upgrades? Engineer coming on Friday to install anyways so will keep you guys updated.
Think they are replacing them all, a high percentage of the original units are overheating/possible fire risks i have heard, they are replacing them all as fast as they can.
Does it (or fibre optic cable in general) have traffic management of some sort? BT lied to to me about this before, so I do not trust their website descriptions.
I also was always checking Virgin's availability in my area, and assumed them to be a monopoly, but only recently found that BT and PlusNet were covering my area for awhile now:)
I asked all 3 different CSR before i agreed to sign up if they throttle at all, they all said NO, then i asked whats the FUP they all said as of last year there is none. I even asked 1 of them i can d/l 1000GB a month with no extra charges they said yes....im so not convinced
Its not just how much you DL, but also when- traffic managment kicks in from 5pm til midnight (on working days, cant remember about weekends). I guess it would be easy to check for existing users - just download some torrent in the morning and again in the evening and compare results :)
Any idea by how much they throttle? From optimum 3mb/s (real) down to what 100kb/s? 500kb/s?
IF something like the first- then I would never consider them, but if its around 500kb/s (real, not kilobits) than its not TOO bad...
