** TEAM XTREEM MEMORY ARRIVING SOON (2600MHz) - SPECIAL PRE-ORDER PRICING! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I am doing two very special deals! On a Pre-Order basis ONLY or until the first 100 units are sold on Pre-Order were offering these two mega kits at this knocked down price:-
Team Xtreem 16GB (4x4GB) DDR3 PC3-20800C10 2600MHz Dual/Quad Channel Kit @ £299.99 inc VAT
Team Xtreem LV DDR3 2600 Quad-Channel CL10 uses selected chips and passes 100% stringent testing. 2600 MHz speed rate with 20,800MB/sec transmission bandwidth and covered in the super slim aluminum heat sink, to lift the transmission speed and quality steadiness to another level.
It is the only one to meet the extremely high standards of the 1T Command rate in the market, and its efficiency is 10% better than any other Quad-Channel memory!
Team Xtreem LV DDR3 2600 Quad-Channel is designated to exceed enthusiast’s high expectations by bringing them the ultimate OC experience.
- Fully compatible with Intel P67, Z68, X58, x79-based DDR3 motherboards
- XMP Ready
- High frequency and Low latency
- RoHS Compliant
- Larger capacity:4 GB Kit (2GBx2), 8 GB Kit (4GBx2), 16 GB Kit (4GBx4)
- Equipped super thermal conduction heat spreader
- 100% Tested and Verified
- Lifetime Warranty
- Data transfer bandwidth 20,800 MB/Sec (PC3 20,800)
- CL-value: 10-12-12-31 1T
- Working voltage: 1.55-1.65V
- PCB: 8 layer PCB
Was [£359.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Team Xtreem 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (TXD38192M2133HC9NDC-L) @ £131.99 inc VAT
Beyond than the shock of overclocking, Xtreem LV is joined by a new and powerful member, Xtreem DDR3 2133. Supported by IMC memory profile, Xtreem DDR3 2133 boasts outstanding efficiency and satisfies the 1.50V regulation to prevent high voltage from causing CPU damage. For the best quality, we only use original granules and with the exclusive granule screening technology, we insure the quality and stability of the materials. At the same time, we keep the strictest standards in quality control right from the compatibility test to pre-delivery test. Our quality is highly trusted by users. In addition, the memory module carries the unique X-shape heat radiation chipset and the high-coefficient conductive gel grabs the granules tightly to maximize the overall heat radiation efficiency and brings the Xtreem series the unique cool touch under extreme speed.
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
- Data transfer bandwidth: 17,000 MB/Sec (PC3 17,000)
- CL-value: 9-11-11-28
- Working voltage: 1.50-1.60V
Was [£149.99] Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
Great speeds for F@H enthusiasts, video encoding, etc. Moreso if you have a 3960X/3930K i'd be quite envious. Would LOVE to see benchmarks across the Team Xtreem range from 2133MHz ~ 2600MHz.
Check your motherboard supports these crazy speeds, my P8P67-Deluxe mobo wouldn't support this as it maxes at DDR3 2200 OC.
Btw, I normally plump for a solid 1.5v memory at rated speeds. It's only the 2133MHz that is rated 1.5v but did OcUK test this because you've posted 1.5-1.6v as the range - official site says 1.5v here. Just wanting to be better informed :)
Would love to see gaming benchmarks between say, 1600mhz and 2600mhz.
I know it probably wont be massive but it'd be interesting to see what good memory can do.
I shall sort this, shall be Quake3 but hey Quake3 will be the game to show any such difference. :)
I shall do following test:-
1600MHz C8
2133MHz C9
2600MHz C11/C12
See how they compare.
