£200-£300 upgrade/build
9 Jun 2009
Ok so at the moment I have a pentium dual core DDR2 ram and its annoying outdated.
I already have HDD, DVD Drive, 500w OCZ power supply
I have a NZXT Vulcan which is ok, but I would prefer an atx mobo, which doesn't fit in, Case wise im the kind if guy that keeps the side of with it looking sexy, and colour coded components, I know the last bits a push because good looking mobos are expensive mobos, I don't mind going amd route because its cheap, I'll also be looking to over clock to the max.
Cheaper the better and it really can't be anymore than £300
Thanks in advanced any advice is appreciated
This comes in at just £17 over your budget but it is a great spec (imho).
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £184.99
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £84.98
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £35.99
Total : £317.36 (includes shipping : £9.50).
If you can't stretch to the extra bit then can change the CPU to the i3 which is still a good chip ;)
Stoner81.
YOUR BASKET
Stoner81.
This is good. Assuming you don't need a graphics card?
Thanks for the build, I Know how good the 2500k is for overclocking from reading the forums, can anyone do me an alternate AMD Build, I would say i3 but I hear they arnt really overclockable..?
Thank You for the responses so far :)
The motherboard I mentioned will support the i3 CPU and you can then upgrade to the i5 at a later time without having to change your motherboard or anything.
Stoner81.
OK I have done a lot of reading, and realised that the AMD Route is pointless, due to the comparison between intel and amd. So an i5 2500k sounds good, but arnt the new intel processors due out soon? when are they? and are they the same socket (1155)?
Thanks in advanced
As mentioned above what about GPU.
Not sure that matters does it? If he is doing an upgrade he may well already have a GPU. Plus the Z series mobos have an IGP anyway.
I'm not sure if the budget included the old mobo bundle being sold off. That would certainly be useful extra cash to get a case and a Ivybridge compatible mobo maybe :)
Thanks in advanced
They are due out in a few months I believe, not sure when exactly. They are the same socket yes (and will run on the same motherboards, though newer ones will be out).
Whether you wait is up to you, the main improvements will be in the integrated graphics - which if you are using may be of benefit to you.
