Dominos Vouchers!
31 Oct 2004
London
Hey guys, ordering Dominos tonight, does anyone have any codes that work? :p
Tried the ones on UKHotDeals but none seem to be working, something like the 50% off £40 would be good! Thanks :D
Yep! but im at work so dont have them on me sorry :( There for my local aswell so im not sure if they will work nationally.
Remember a lot of Domino's codes are area/store specific so may not work, it's not a good sign if the ones on HUKD don't work!
Same here - i will see if i can get home and get them for you ASAP (plus it would mean i can leave work early :p)
Go to a local pizza place and then you won't even need a discount code. Better food for much cheaper.
If you're ordering online then MSMEXCLU may give you 40% off a £35 spend. Obviously depends if they accept that in your area and what not.
NUSEXTRA if i remember correctely seems to get you either £10 off when you spend £30 or its 25% off. Online i take it?
I've got a few of them at home for 50% off when spending 30 or 40 quid (can't remember) which might work. That's unless they're local only as I got them with my last delivery.
Someone give trixilux on minecraft a shout later to remind me.
Same here - i will see if i can get home and get them for you ASAP plus it would mean i can leave work early :p)
Wait a minute, how do you justify that lol?,
You - "Yeah boss i have to go, there is an emergency, someone needs some voucher codes for dominos..."
Boss - "Then why are you standing here go go go"
You'd need 100% off vouchers to make dominoes worth it.
