PC for Video Editing
4 Feb 2011
Looking for a system that can render 720p-1080p videos at 10-25 minutes long on after effects in as quick a time as possible. I use Hauppauge and in the future I'll be using Blackmagic devices and the file sizes are usually 1-2GB.
Something that can get the rendering times down to 15 minutes or shorter is what I'm after and I don't have a clue what I should be purchasing. So hopefully someone on here does something similar and can help me out.
Thanks
Wouldn't know how to set it all up I'm afraid unless it's as simple as connecting some tubing from one end to the other ?
A custom loop is a lot more than that, you have to fill it with all the liquid, fit all the water blocks and it requires maintenance as well.
Alternatively, you could get one of the closed loops from Corsair or Antec which only require you to mount the block as you would an air cooler and they do not require any maintenance.
£3,000 budget
would need a mouse/keyboard/monitor though wouldn't mind upping the budget if I could get some kind of 3 way monitor eyefinity type thing going however (and keep performance high)
Okay no problem. If you don't want the hassle of watercooling that's fine, modern systems can be cooled very nicely on air, or you can get small, sealed water coolers which just cool the CPU and require no maintainence.
Just to be clear, is this for gaming or just editing?
Or buy one of OcUK tech labs watercooled cases. They've done the hard work and pre-filled as well I beleive, all you do is build the rest of the pc as usual and attach the waterblock.
Check here for the range and details
Got one on my shopping list.:D
Just for editing want to get those renders out super quick annoys the hell out of me using my current PC to do it all.
Yeah way over my head :D as I thought
