BEST UK PRICE - PHANTEK COOLERS
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
Pricing is now even better on the high end Phantek Coolers!
They are a performance monster and a thing of beauty.
Phanteks PH-TC14PE CPU Cooler - Silver (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £64.99 inc VAT
nonl2br Phanteks PH-TC14_PE twin tower thermal radiator design uses the latest aerospace technology. By using P.A.T.S to increase cooling performance and C.P.S.C Technology to enhance thermal conductivity, heat will easily dissipate, creating an opportunity for greater overclocking. Combined with Dual Phanteks PH-F140 Premium 140mm Fans, easy-to-install SoliSku mounting kit and PH-NDC thermal compound, Phanteks PH-TC14 with unique colored is setting the new standard of today’s CPU cooling.<br>
<br>
- Intel Socket LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3 (stock backplate required)<br>
- Fan Size: 140x140x25 , Dual Fans included.<br>
- Fan Compatibility: 140x140x25mm x 3 pcs, (120 x 120 x25mm x 3 pcs). (Third fan clips and accessory included).<br>
- Bearing Type: UFB bearing (Updraft Floating Balance bearing)<br>
- Blade Geometry: 9 White colored Blades with MVB (Maelström Vortex Booster) Design<br>
- RPM: 1200 RPM ± 10%<br>
- RPM with Q.S.A: 900 RPM ± 10%<br>
- Max Air Flow: 78.1 CFM<br>
- Max Air Pressure: 1.21<br>
- Acoustical Noise: 19 dBA<br>
- 5 Year Warranty<br>
<CENTER><IMG SRC="http://img256.imageshack.us/img256/6861/awardsjq.jpg" height="150"/>
Was £72.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Red (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £64.99 inc VAT
<br>
Was £72.99 Inc. VAT
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Blue (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £64.99 inc VAT
<br>
Was £72.99 Inc. VAT
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Orange (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £64.99 inc VAT
<br>
Was £72.99 Inc. VAT
ORDER NOW
Now cheaper than the NH-D14, and only £10 more than a silver arrow makes it a no-brainer really.
Trying soooo damn hard not to buy one.
I'm close trust me, the blue one would go well with the chipset heatsinks on my P8Z68!
Its going to have to wait a week or two if I do having just spent ~£150 on a sound card and headphones ;)
btw helios I've just picked up the card from the PO I'll leave trust and update the wanted thread in the morning when I've fitted it! nice box too :p
Helios would you put the H80 on a par with the 920 (as I can't see the H80 in you're cooler roundup)? If so that makes this cooler nearly 4c cooler!
Edit: also this cooler is worth the £65/€80 as at the moment it is the best aircooler on the market.
Awesome hehe. Hope it works well!
I've never used the H80 but there shouldn't be much difference between it and the 920. Both use very similar radiators and fans, and the pumps I imagine aren't very different. So yeah, the Phanteks would be better.
It's definitely worth the price at what OCUK have it at, especially when they actually have it in stock compared to the Silver Arrow which tends to be very rare.
Almost true, its 21p difference but the other place is another £4 shipping. Ocuk's price + free shipping = win!
Just like shipping is free for us for being forum members, it is the same there. So i get free delivery on all parts, best thing is they dont provide anything but next day (sure they give an option to deliver later days but by default that £4 is next day).
