Just bought a 2nd hand bundle of q6600 (will oc to 3ghz) m/b and 4gb ram from a mate. Which graphics card would you recommend as a good match?
Am going to upgrade my monitor shortly, so gaming at 1080 on 24" or 27" TN panel would be the max possible (I imagine I won't achieve that but if nothing else it defines the upper limit)
Was thinking of the GTX 460 - is that overkill for this CPU?
By the way - want to go the nVidia route so in the future may try 3d (though with a future cpu I guess!)
Thanks for your advice.
