Half Height GCARD which one???
Need a gcard for my work pc, what is the best I can point them in the direction of for less than £100?
Its going into a hp PC.
Matt
Need more info
agp/pci-e
what power supply has the pc got
does it have any pci-e 6-pin or 8-pin power outlets
does it need to be single slot or double slot
etc etc etc
Sorry, for not providing those details.
PCIE, not sure what cables are on the psu, there is 2 or 3 slots free in back of the case.
Think its a HP dc5800, core2duo E8400 and has the standard power supply fitted.
Matt
If all you need is a card to provide a display then try an ATI HD 5450 or HD 6450, ~£25-£35.
If you need it to do more than that then you'll have to say what.
This ^^ we need more details? Presumably you're not going to be gaming on it as it's a work PC?
yeah if all your doing is abit of pong your wasting your money at £100 .. £30 will do the job for display purposses
