Prospective Build - Any Glaring Errors?
16 Jan 2012
My first post, so a quick hello and a request to give my prospective build the once over: I'm a Mac guy, but also a Hackintosh guy, so this machine will be a dual boot with Windows 7 and Mac OS X 10.7.2. I have to go with a Gigabyte motherboard for Hackintosh purposes, but everything else is negotiable, but remaining on a budget. I'm looking to overclock the processor, hopefully reaching 4.5Ghz, or somewhere close. I never play games and will probably using the HD 3000, so I mightn't be your 'usual' sort of poster. Here's the build, any suggestions and/or advice are gratefully received:
Case: Corsair 300R
MoBo: Gigabyte GA-XP-UD3P
Processor: Intel i5-2500k
RAM: 8gb Corsair Vengeance RAM (or maybe the G-Skill Ripjaws?)
PSU: OCZ ZT-550W
Cooler: Corsair H60
SSD: OCZ 60gb Agility 3
the motherboard is socket 1155? Doesn't look like a model I recognise. They are usually named 'P67' or 'Z68'. like the Z68XP-UD3P, Z68XP-UD3, or the Z68AP-D3 but I would go with a higher end model if you have the budget (I don't like the weedy VRM designs for overclocking). Gigabytes have HDMI outputs, Asus and other manufacturers usually support HDMI or DVI.
And from what I read, and personal experience, I would get a Crucial M4 instead of an Agility.
And, I have a dislike of OCZ psu's. If you have no intention to have a graphics card in there, I would pick up a Corsair CX430. Or if you want the option later, a Corsair TX, Antec TruePower New 550, or a XFX Core 550 (all Seasonics).
In any case, apart from the motherboard, it looks compatible.
Hi, thanks for the reply. Sorry, left off the Z68. It's a GA-Z68XP-UD3P. It can be found here on the Gigabyte website or here at overclockers.
Really? I thought the M4 was much slower?
I wanted a fully modular power supply really. Without going into silly money, that is.
Yeah I like the Z68XP-UD3P. If you don't mind HDMI interface.
On paper maybe, but practically, not really. Maybe in write speeds, but that hardly matters for things like programs and OS. All I know is that there are far fewer problems with the M4, and I value that more than pure speed in a drive. Also keep in mind that sometimes there is a discrepancy between the 128GB and 64GB drives in terms of performance.
Then the OCZ is worth a punt.
Note that the write speed of the M4 64GB is half the write speed of the M4 128GB. The IOP's and small file performance are roughly similar however. All in all, my guess is, may a couple of seconds difference for OS loading time, so hardly something to worry about. Looks like it's worth flashing to the latest firmware though.
http://www.storagereview.com/crucial_m4_ssd_64gb128gb_review_firmware_0009
