Makes of Jeans you have found to be good?
3 Dec 2004
Hi all,
What to get some new jeans soon and the ones I have been looking at recently are rubbish (loads of logos, rips, super skinny).
I just want a plain pair in boot cut style that has a little bit of quality to them (around £40-£50). Anyone know of any makes they have found to be good?
Diesel, Levi's, superdry, g stars and jack jones.
Levi's are the obvious.
Jack and Jones are probably your best bet for that price though
Fat face, same as ralph lauren, same factory, same material, 3/4 of the price :)
If your into names that is, but the quality is very good.
I don't tend to go with particular brands, I just buy the ones that look good on me when I try them on (which isn't that often cos I'm 6'4).
Got a couple of nice pairs from Next recently, only £25 each and they look great.
Just go shopping and see what you like the look of, then try 'em.
I just buy M&S jeans the stormwear ones find they last a long time and are nice and simple but then im not a fashion man :D
H&M. I haven't found anything as comfortable about them even when doubling the budget and then some. They fit great (ignore the silly fashiony ones), are cheap and are hard wearing.
Last time I went to look at them, some were only 70% cotton as oppose to 100% like other named brands.
He may struggle to get some decent Levi's that he actually likes for £50 though.
The only Levi's I'd wear usually cost double that. I'm picky though, tbf.
Oh. I just checked one of my pairs and they are 100%. It would be a shame if they've changed to 70% to save money as it'll obviously effect the quality. I'll keep an eye out next time I buy a pair!
Can never go wrong with Levi's!
Recent bought some Animal (just the plain sort) that are very well made and fit well. Had fcuk in the past that have also lasted really well
I struggle to find jeans that fit me and as well as looking decent, but I've found for me, Diesel and Firetrap are the best! :)
