MSI Afterburner FPS Counter
Caporegime
4 Jan 2011
Hi,
Just reformatted my PC the other day and downloaded afterburner, have they changed the FPS counter so that it now has annoying text and is spaced about instead of being tidy in the corner or does someone know how to fix this?
Examples below
17EB5175488CB5774466C8F26E30292585F5D0B6
Click on the 60 icon in the bottom right hand corner above the airplane this is for the osd display, click SHOW. Click on GLOBAL and adjust the on-screen display zoom, you can also adjust the spacing and location of the display :)
Ive been looking for this counter, where did you get it, I recently downloaded Afterburner but I cant see an option to activate any in game counters?
Click on the afterburner icon, show, in the opened up software click settings, Monitoring Tab, highlight an option you want displayed then click the box Show on-screen display. :cool:
Click ok
Don't see where I can adjust the spacing but not see the massive D3D11 there for absolutely no reason :p? How do i get rid off it?
