Hey guys I have a aquaaero monitor currently installed in my system and while im marking up components to upgrade my loop(s) I figured it high time to make use of this hardware.
With that being said there are two sensors ive found that I can use.
Unfortunately OCUK do not stock sensors (seems kinda silly as they provide the expensive hardware but not the little connectors to actually utilise it) so ill need to go elsewhere for it.
That being said id like to know which would be 'better' for me to use. The two options are a "Bitspower BP-MBWP-CT, Temperature Sensor Probe, G1/4" Thread" or a "Aqua Computer 71162 Temperature Sensor Inline".
Judging from the looks of those one plugs into a T junction while the other is placed within the actual loop effectively having the fluid run through the whole thing. I may be wrong here but that is what I gathered at a glance.
Anyway what would you guys suggest out of the two?
Also if you know of any others that may be a better option please let me know!
Thanks in advance!
Thanks in advance!
- much neater - I have three in my system along with an temp probe which I used in my res all connected to my AE5 Pro
