Hmm just realized I won't be able to have both my hazro and the benQ hooked up on my single 6970 as they both use dual link dvi. :/
120Hz works on Displayport too.
Does it? I thought there were limitations through displayport.
How else would this guy http://forums.overclockers.co.uk/showthread.php?t=18331050 run his setup?
He uses AMD cards. On AMD cards, all displays have to be connected to the same card, even in like, quad Crossfire. With an AMD card with 6 Mini-DP connectors, you can connect 6 120Hz screens.
http://forums.overclockers.co.uk/showpost.php?p=20636168&postcount=35
Edit: he even has 5 120Hz screens now. http://forums.overclockers.co.uk/showpost.php?p=21082131&postcount=66
Well, apparently you can... I've never used it before either. Got my BenQ connected through Dual-Link DVI.I know it can be run but what I didn't know is that you could run things like 1600p monitors and true 120hz monitors efficiently through it. I've never had the need to use a displayport cable before.
Can anyone recommend a good displayport cable to miniDP?
Looking at buying.. Do I need a m to m dual dvi or m to f dual dvi sure it's m to f but don't wanna buy wrong one. Thanks
Just set it up. WOW. 120 hz is absolutely amazing. It's so damn smooth. Just had a blast on BF3, I cannot belive it.
Just one thing tho!
1 dead pixel.
Shall I return under DSR?
Just one thing tho!
1 dead pixel.
Did you get yours from ocuk?
No mate I didn't. How do I go about sending it back under DSR?
They probably won't take it back with only 1 dead pixel but you can return it for any reason within 7 days of delivery with DSR. So just ring them up and organise a collection or something. But you will have to pay for the return postage yourself most likely.
