Check my spec please :)
7 Mar 2011
Oldham, Lancashire
Just putting together my basket for a new build and would just like to see if anyone has noticed any glaring mistakes? I haven't built a PC from scratch in 11 years! I know there is no graphics card, I dont particulary need more than the HD3000 in the CPU can handle (and tbh my laptops so banged up I cant really work on it anymore). I am also aware there is no copy of Windows, I am a Linux user :) Though I will add Windows and a 2nd SSD at a later date. A traditional hard drive isn't needed, I have a 1TB NAS drive that I will mount on boot. Thanks for any advice :)
OcUK Tech Lab - V12 Watercooling Kit 360
Intel Core i7-2700K 3.50GHz
Corsair Obsidian 800D
Corsair Professional Series HX1050
Crucial RealSSD M4 128GB
Asus P8Z68-V GEN3 Intel Z68
Corsair Vengeance Blue 16GB (4x4GB)
Samsung SH-B123L/BSBP 12x BluRay
A 750w psu would do. As said above if you are just going with the on cpu graphics, maybe even a 650w unless you are planning to addings graphics later?
Also unless you need 16gb ram you could save a few more pennies and get a 8gb kit.
Other than that, looks good! I'm after something very close to your setup. Waiting for the Corsair obsidian 550D case though.
I'd like to keep the PSU, purely as I *may* add a graphics card. I am being bugged by friends to play eve-online and WoW lol.
The Blu-ray is OEM, but software isn't needed as it will be windows anyway, and my PC will be running Linux. Besides, I have yet to find something mplayer can't play :)
No free software can play bluray as far as I'm aware?
Also the PSU stulid specced is great and will run ANY graphics card, even two high end ones without issue. So you really don't need >1000W!
My main worry with that is that if I want to upgrade to 16GB later, I may not be able to get the same blue ram sticks lol.
The 850w PSU I linked to is enough for any single GFX card, its even capable of running a pair of GTX580's in SLI mode.
OK I have swapped to the power supply stulid advised, and dropped to 8GB of the same RAM.
lol I am getting that giddy feeling now, like I'm 18 again!
Huge case!!! that will last eons.
Thats the plan. The staff here helped me out with an email, advising the 800D over what I was hoping to use (it had no room for the tripple radiator) and I have been youtubing it. I lobe the space, and the simplified look on the front.
And the black matches my bedroom, I shall add blue lights obviously.
