Hi
Could anyone give some advice on water cooling inside HAF x case.
My motherboard is Fatal1ty Z68 it has fair size heatsink and i am looking to fit a XSPC RX Series 360mm Triple Radiator : RX360 at the top of HAF x and use 3x 12cm Enermax U.R.Vegas USB 5 Volt fan with magnetic antivibration rubber frame and red LED light but i have my doubts that the radiator will fit in HAF x and the heatsink on motherboard would be an issue with that last fan at the back i think but not 100% sure.
Perhaps someone here watercooled HAF x before with a motherboard that has bigger heatsinks or the same size and used a thick 360 radiator at the top.
Any advice is appriciated. Thanks
