asrock z68 extreme4 gen3 or asus z68 pro gen3
I had the same dilema. I ended up going with the Asrock due to the easy overclocking. Really impressed and no problems so far ;)
This was after buying the Gigabyte Z68AP first and it breaking within 24hrs! Took it back to overclockers for testing and they gave me a refund.
This motherboard is just sooooo, ridiculously, insanely, good, I achieved this benchmark at 5.1 GHz on AIR how can this be possible?
http://3dmark.com/3dm06/16383529
AsRock Z68 Ex4 G3, [email protected] , G. Skill RipsawsX 8GB,
5850 1GB(CFX), CM90 II Advanced, Crucial M4 256GB, 4 HDDs,
NH-D14, XFX 850W BE, Xonar Essence STX, BlackGold HD DVB.
Thanks guys, you really have me stuck now :(
Very happy with my Asus Z68/V GEN3,however if you want to make the decision easy stick to the budget you have and look at features you need then make a decision,one of the reasons I went with Asus is excellent UEFI BIOS and Intel Nic,excellent overclocker
Btw all Z68 boards are easy to overclock if you got Intel 1155 K type cpu,just a case of increasing the multipier in BIOS that simple,don't need software to do that ;),but if you do need software OC program you can with Asus,Gigabyte,MSI etc... since they all have that so not an issue.
Thanks am going with asus :) like the Bluetooth built-in, UEFI BIOS looks great, intel lan lots but asrock does look nicer.
