A quick question regarding the fans.
Ive noticed the scythe fans are apparantly the best on the market for cooling and noise performance and as such I have been tempted to get these anyway. I do however love my current xigmatec fans, purely because they are purple and im going for a purple colour scheme with my final build (already have my G19 and Naga on purples alert!). With that in mind is it worth me getting the 3 scythe fans and placing them beneath the radiator so as to use a pull/push system for my rad?
yes, although you may get some noise due to different fans causing buffeting and turbulent air etc, this can be avoided and configured using a fan controller though
Would having slower fans being the first pull for cool air hamper the performance and basically waste the whole point of using scythes?
it'll be fine
If so is there some way in which I can mod these scythes without again hampering their performance but allow me to add purple LED's to them?
yes, tealc did a very good guide on it
Thanks again!
Also in regards to that reservoir, would it be considered the better of the bay reservoirs out there? I will most likely be able to show off my fluids the most from the front of the case so im looking for the most aesthetically pleasing (or fluid exposing) res while retaining a decent level of functionality and efficiency.
any res will do. My personaly all time favs are the EK dual bay spin res'
Yes im a fussy bugger
Thanks again!
) and at the same time I was thinking of getting a quick disconnect shutoff coupling.
