The HD2000 is half a HD3000, so a HD3000 is half as crapGiven that the 2120 and 2125 are pretty much identical apart from the graphics, you may as well get the slightly better IGP!
No.
Its really not worth it.
That looks great, i prefer the vantage case tbhIs the Asus board in my first post as good as that Gigabyte one?
is it worth going for the Asus? i think it has more PCI slots etc...
I am guessing the cheaper PSU will be fine![]()
Thanks for the help, i might adjust the list to the Asus board and a WD HDD and i reckon that will be it!What do you think?
Awesome, that HDD is on my listUp to you, they are both decent boards. depends what features you want/will use really.
Yeah, that PSU gets decent reviews and will run that system fine.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=231
I'd get this HDD instead:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-081-SA&groupid=1657&catid=1660&subcat=1664
I think its marginally faster, but they are all very similar.
Awesome, that HDD is on my list![]()
Sounds good about the PSUand the Motherboard
Is the onboard sound alright? its Realtek i believe![]()
Yeah onboard sound will be sufficient
(Just a side note, I think your signature is too big. check here:
http://forums.overclockers.co.uk/faq.php?faq=vb_board_usage#faq_vb_memberlist_how
best to change it before a mod removes it)
I was originally looking at the 500w Coolermaster i believe, i will have a look now, is this the one? http://www.overclockers.co.uk/showproduct.php?prodid=CA-167-CM&groupid=701&catid=123&subcat=1103There is a coolermaster 500W supply for £50 and that is modular. Better than what you were originally thinking.
Onboard sound will be fine. I cant lie I use an old PCI creative audigy 2 soundcard as it sounds better than my 7.1 onboard audio. That said i already had it and certainly wouldnt have bought one to replace the onboard audio.
Ermm, whoops :/ do i get let off as i am only 13?You sure like using plenty smiles don't you![]()
Ok, i will remove one of the bullet points
Ermm, whoops :/ do i get let off as i am only 13?i will try and calm down a bit
I'm probably getting a card mate
Are the OcUK Swift PSU's good? Is there anything else i can buy that is cheaper to get the price down?
Awesome, will it be ok for what i want to run? obviously i would upgrade if i want to run anything more powerful, i will make a basket and show you what i have on my list at the moment
Are the TP-Link ones good? Any other ones that are cheaper but will work? Still, its only encase i don't go for wired, well, if i can't![]()
Also, is it worth going for Lightscribe DVD drive, its a nice touch but is it worth it?
Thats it so far, getting more and more expensive! Anything i can get cheaper? Wireless card seems expensive :/ Are the TP-Link ones good? Any other ones that are cheaper but will work? Still, its only encase i don't go for wired, well, if i can't![]()
I will look at some TP-link cards, thanksI've been using my TP-Link Wireless card and Wireless router for a year now, no problems here.
Lightscribe are not worth it in my opinion, unless you want to print out dull black and white covers on the disc. Personally I would stick with a standard DVD drive.
Awesome, should be getting ready to build really, birthday is on 30th march so I will keep look out for some parts until then, probably going to be a joint christmas and birthday to be honest and I will have to ask my nan for an OSLooks good to me. as above, I'd just get the cheapest DVD drive myself.
I have found a ocuk DVD drive for 15quid not the best but it has fairly good reviews and it's only there if I need it
Awesome, should be getting ready to build really, birthday is on 30th march so I will keep look out for some parts until then, probably going to be a joint christmas and birthday to be honest and I will have to ask my nan for an OS![]()
