Pentium III and Linux distro?
1 Mar 2010
Voting Conservative.
I have been given a pentium III computer 550 katmai CPU, I am upgrading it to Coppermine 1.0GHz (£4.99) as it is an apollo 133A chipset and also adding 1.5Gb SDRAM (£7.50). I intend to add my 250Gb IDE drive to what else is already there and run Linux. It has a 2x AGP Rage graphics card and an antique Voodoo 2 3dfx card.
Any thoughts on a good distro for this? I do not want to run windows at all.
OP Resist this hypocrisy.... Get yourself a hardware accelerated Nvidia GPU and you'll be laughing on linux
Funnily enough it does have 2000 on (not for long). Yes, this is Linux all the way. I did use Linux a few years ago probably on a later machine than this, but the spec 1Ghz, 1.5Gb etc. sounded reasonable and I shall look out for a GPU.
I have a Radeon 7000 32Mb PCI or the aforementioned AGP card just to get up and running. This is a budget box and am aiming to come in at about £50-60 so any thoughts on a specific model for ~£50 or less would be good. Geforce 6 or poss 7.
I would put Gentoo on it. Source based, and no automated installer so it will take *days* to get up to a day-to-day usable state, but you can get it to be very lean.
I preume the machine has pci slots? You can get an 8400GS 512MB in pci new for a shade over 40 quid or you can get a Zotac GT 520 512MB in pci for a shade over 50 quid.
Overall if you're going to shell out 50quid for a graphics card why not instead dump the platform and buy an ION-ITX .... seen some go pretty cheap on MM
No I am not going to shell out hugely for GFX card. Could just dump it but I have spent £12.50 on it (last of the big spenders heh). Anyway I like playing around with different stuff and I do not really need another computer :)
Will look out for a super cheapo 8400GS, may take a short while, thanks to all for advice on this thread,
andy.
I have a P3 1ghz machine myself running PCLinuxOS LXDE lightweight, and it's running very well indeed :)
