So, tempted by this 528 auto, looks nice, has full BMW SH, but is on 170k miles.
Probably one for Fox here, but is the car nearing the end of it's life or what? Stuff going to blow up all the time on it, autobox good for high miles?
I normally wouldn't even consider it, but this one is ridiculously cheap.
Define cheap I suppose!
I paid sub £600 for mine a little over a year ago, granted, it was the far side of 260k miles then and is now past 270k miles yet is still on its factory exhaust & (more worryingly perhaps) its auto gearbox.
If the car shows signs of being well looked after , like a detailed service history, decent tyres all round etc then @ 170k miles, it should have plenty of life left in it yet.
It was easy for me though, my car was owned by my fathers business from new & he kept it when he eventually retired. It was still getting regular BMW servicing @ 11 years old....
If you have found such a needle in the haystack, then buy all means take a punt on it.
It'll still cost you to keep it on the road - if doing it properly - but, its worth it imo.
In the 12 months I've had mine, its had suspension drop links & rear pads replaced, the drivers door handle broke on the inside, dash pixels are crap (which some days work fine, others not at all) and routine servicing.
I have spent way more than I paid for the car with the above and as Fox points too, this is where most aged e39's fall down. Owners either can't afford or justify such expense on a relatively cheap (to buy) car.
