Hi all. Any ideas why my central heating pump won't switch off?
Boiler is a Vaillant Ecotec Plus 418 Condensing boiler, it is controlled by an iflo programmer. There are two electronic valves, and there is a hot water cylinder with stat upstairs.
I know that the boiler is supposed to overun the pump when the boiler shuts off. This is meant to be for 5 minutes.
However, I noticed last night that the pump was still going long after the heating had been turned off. I thought nothing of it, and went to bed. The heating or hot water was not set to come on at all overnight.
So this morning I checked it again, and the pump is still on. The rads are cold (as they should be), but the pump is hot. The screen on the boiler was showing approx 70deg. It is pumping water around the hot water cylinder circuit.
If put the heating on, then the valves move as they should and the rads warm as they should. But then once the boiler turns off, the pump keeps running.
The boiler has an information button, which tells you what state it is in when you press it. Overun is S7, and this is displayed for 5 mins after boiler shut down. After 5 mins it displays S0 (no heat required) and the pump just keeps running.
The boiler, programmer, cylinder stat and valves are all around 6 months old. Is there anything simple I can try before getting a plumber out?
(yes, I've tried turning it off and on again
