Hi all i'm attempting to find a worthy upgrade for my current system with a budget of around £600. The only parts i need to replace are the mobo/cpu/ram
Currently using;
Asus P5N32-E
Intel Core2 Quad 2.4ghz
DDR2 800mhz 4x1gb
Having looked around Overclockers i've come up with;
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - Retail
Asus P8Z68-V GEN3 Intel Z68 (Socket 1155) DDR3 Motherboard
Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Dual/Quad Channel Kit (CMP16GX3M4X1866C9)
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3
which totals to £573.95.
The intent on the upgrade is to have a significant increase in performance that should last me for many years as what i'm running at the moment is far from doing good and shows its age. Even buying DDR2 costs well to much for the current board.
Thanks for reading and additional thank you for any suggestions you make
Currently using;
Asus P5N32-E
DDR2 800mhz 4x1gb
