UKCS:BF3#1 - Conquest - www.ukcs.net
Thing is angst, the game was fine before the inclusion of the slider. I had no issues prior to the patch that it was included with.I find i have to fiddle with that slider everytime i join a server to get the reg even half decent.
I have mine half way Neil and i get wicked reg I find all the way to the left or all the way to right I get really bad reg! I always adjust it around the middle depending on the server and my reg is spot on!
So try that!
I'm still getting the RESTRICTION: Service Communication Failure: PnkBstrA.exe error can anybody help?
Which was happened on another server, I was already down on the ground for atleast one second but the guy who killed me said I was still standing up.
How is that playable?, there's a pretty huge delay from what i'm seeing on my screen and what is actually happening. Though I can go play later on the same server and it'l be fine!
Make sure the services is running, you can do this via services.msc. You could always download the pbsvc program that makes sure it is running ok, get it from here
Adjusted slider, played abit of metro
62/22
Thanks Westie will see, might just've been a good server :/
Doubt it was the server i was rubber banding at points and yet half an hour before on a different server i was fine.
