Some SSD & Gpu advice needed pls
9 Oct 2011
Edge of Sanity
Howdy, probably been asked a zillion times but hey! I'll ask again and apologise for the repeat thread if so.
I've been offered a Crucial M4 128gb from a mate, who just upgraded to the 256gb, problem is I'm currently saving up for a new graphics card awaiting what the new models offer in the next few months.
The mobo I'm running at the moment is a GA-P55a-UD3 on F11 bios, through some brief googling I know there are problems with the marvell controller on this board and more recent SSD's.
So I know one day I will need an SSD, but a GPU more powerful than my ASUS CUtop GTX 460 768mb will be needed eventually.
So any fixes, hints, tips or advice will be muchly appreciated. :D
Edit: System Specs not mentioned so far.
PSU: Antec Trupower 650W
Monitor: Viewsonic 20inch at 1680x1050
Ram: Kingston Hyper 8gb (2x4)
CPU: i5 760 @ 4.01
Cooling: H50 with p/p GT 1850's
What resolution do you play on? For most games you can still play with a 460 at med settings.
SSDs are nice, and fast, and the M4's are one of the best SSDs out there.
But on the other hand, I'd expect the 6XX series from nVidia to be fairly good if it's going to compete with the 7xxx series....
kd
The 460 is an ok card for now, maybe pick up another one second hand and SLI to tide you over?
I'd certainly take the SSD. Best upgrade IMO
Aha knew I forgot something! 1680x1050.
Also been nosying at a bigger monitor for gaming and design work, whilst keeping this current 20 inch as my anti alt tabbing monitor. Think I may require a more powerful card to run two monitors.
current card is fine
1680x 1050, you'll be fine for a while with your current card :p
What puts me off a SSD if the mass reinstall of a lot of programs but my system has been due a good tidy/partitioning etc. Just laziness really.
Did think about SLi setup once but another 460 will cost me about £70 more or less, & I've never done that before so wouldn't know whether it should be x8/x8 or x8/x16 can always read up on it.
Suppose I'll always need an ssd, just with it not running at full speed does put me off a little but with my board being the older gen.
Mate is offering me the drive for £110, might try and get it for a ton with a couple of pints if I decide what im going to do in time :p
Thanks for input so far and in advance.
