where to put SSD?
8 Sep 2011
united kingdom
ive just ordered the M4 64gb SSD and was wondering where is the best place to put it in my Haf X 942 case as some people mount them else where around the case so any ideas.
Hi there,
As Cleeecooo mentions, you can really stick the SSD anywhere you like - since they are very small, don't have any moving parts and aren't too sensitive to heat. Velcro is a pretty cool looking and practical way to attach one of these drives to some unused space in you case.
Alternatively you could install the SSD in the 2.5in/3.5in hot-swap bay that comes with the HAF-X. Or you could buy a bay adapter like this and slot it in one of the 3.5in bays.
I just bunged mine on the floor of my case's lower chamber. There were power connectors and sata connectors there spare from my old third installed drive. Mine came with a converter for a normal drive bay but I have already used up my drive bay with a bungee mod. It works and I'm not anal about the appearance of the bottom chamber, or the top for that matter.
I just left mine on the floor of my case, like Tealc.
Didn't have a drive bay converter and couldn't be bothered to do anything more elegant. After all, it doesn't make any difference, just aesthetics if you have a windowed case. (I don't)
I saw a how to another forum where the guy used elasticy red string and but a kind of bungee nest for his ... very cool
Can't find it now tho :/
Got mine on the side of the optical drive cage with a few cable ties, as has been said, You can stick it anywhere and doesnt even need to be fastened in place if you dont move your PC much
how long will it take for my ssd to turn up, because i picked DPD next day and my order print out says delivery date: sat 28th but i didn't choose the saturday delivery option because that cost's ₤13.50 :p
