My Sky router stats
19 Oct 2002
Torbay, Devon, UK
Hi
Today is my day 10 of my Sky internet, how do my stats look. (basicly same as o2). Is there anything I can ring up and get sky to change.
Router Statistics
System Up Time: 232:43:27
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 64758 64597 0 10 25 9:20:49
LAN Up 16325049 9509467 0 743 2258 232:43:27
WLAN Up 2084930 1452996 0 2005 366 232:16:18
ADSL Link Downstream Upstream
Connection Speed 8807 kbps 1012 kbps
Line Attenuation 36.0 dB 18.7 dB
Noise Margin 7.6 dB 9.0 dB
Thanx
The noise margin looks a little high, the normal noise margin is 6db
See what happens after today and see if your router looses the sync tomorrow as it may connect at a higher speed, as on a 36db attenuation you should be able to connect at 9-10mb at least (I presume that all of your phone line wiring is in order in your house?).
Liam
Liam
Was a new line put in last march, I only have the main socket and Im plugged in to the test socket.
Wait a couple of days and then I would ring Sky if nothing changes, they should be able to do something about the SNR and they could put you on a 3.0db SNR profile.
Liam
How far can it safely go before it drops? since 7 is the target. I had went 39 days without a drop. Router uptime currently sitting at 1562 hours.
Instead of creating a new thread can someone cast their eye over my Sky LLU stats?
Connection Speed 6141*kbps 796*kbps
Line Attenuation 44.5*dB 26.4*dB
Noise Margin 6.1*dB 12.0*dB
Was at just over 7000kbps a few weeks back?
Looks about right, I have the same att as u and get 7.
mine isnt looking too great :\
Connection Speed 5024 kbps 796 kbps
Line Attenuation 36.5 db 18.5 db
Noise Margin 13.4 db 13.0 db
Iv had mine go to 3 before and still be totally stable, saying that on those rare occasions that happens and i notice it i useually reboot to get it back to 6/7. But if the line is in decent nick, going down low won't be a bother, its only a headache if the line is not good.
Vintage have you called them to see if they can up your speeds at all.
Here is my 5mb capped connection, i asked for it to capped at that, as after much testing it was the fastest stable speed for me, could go faster but would drop out from time to time.
Connection Speed 5023 kbps 798 kbps
Line Attenuation 46.5 dB 28.4 dB
Noise Margin 7.8 dB 13.6 dB
Your Line Attenuation is a lot better then mine, so you should have a fair bit more head room to go on the down/up speeds, especially on the down as your noise margin is so high. Give em a call and ask them to tweak it for the fastest possible speeds.
As that speed to me looks like it was the automated software that set that speed, mine was set to 3.5mb until i rang them and got it tweaked. Its always worth a call.
Router Statistics
System Up Time: 317:36:39
WAN PPPoA 3846396 6819278 0 2519 0 94:14:01
LAN Up 21078045 12028461 0 76 19275 317:36:40
WLAN Up 3524325 2383640 0 0 695 317:09:31
Noise Margin 5.4 dB 7.5 dB
my stats today.
Ah, I see. The lowest I've had mine go on a freezing hard frosty night is 5.0. It's normally solid 6.0 to 6.4 during the day, 5.9 at the moment. I'm now pushing 68 days uptime for the router.
I phoned them up a few years ago when we still had the netgear router and that was what they set my line up as because anything more it would drop out every 5 mins or so but we do have the new sagem router and they have upgraded the exchange since so will give them another ring and see what happens. Tbh it didnt really bother me too much until I started watching stuff off anytime+ and had to wait 30 - 40 mins for films to start
WAN PPPoA 9108 14865 0 2183 5623 0:03:25
LAN Up 30294457 16055459 0 85 3009 41:27:47
WLAN Up 1231501 658934 0 324 518 41:27:25
Connection Speed 8991 kbps 989 kbps
Line Attenuation 36.0 dB 18.6 dB
Noise Margin 7.1 dB 11.0 dB
I have just rang sky, and they say Im on the best profile, and can not change it. And yes first of all. She said they cant change my gaming profile, I have to change it on my console. lol
