Not another what should i do thread :)
27 Mar 2003
so has been years since I last upgraded my pc and was wondering if it is even worth upgrading my system or look at doing a complete refresh.
i currently have an e6600 2.4ghz based system 4gb ram, 8800gtx on an asus rampage formula x48 board.
so what would be the best thing to upgrade. i mainly use the system for development work but encoding as well. so if i could get hold of one maybe a quad core processor would be a wise investment. Thoughts oh wise ocuk gurus?
I would pay 60-70 for a q6600 and overclock to 3GHz+ You would see the benefit in the encoding and day to day use.
Maybe treat yourself to a 64GB ssd for windows and your development work.
Edit:
You might need a cooler.
as everyone else has said, a Q9550 and a decent cooler (that supports socket 1155) would give you the most performance now. however, the other option is to go for a smaller upgrade but set yourself up for a sandybridge later
something like this:
YOUR BASKET
1 x Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard £99.98
1 x Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £88.79
1 x Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £17.99
Total : £206.76 (includes shipping: FREE).
that would give you an upgrade path to any socket 1155 sandybridge or ivybridge, all the latest motherboard gizmos and crossfire and SLI support
the performance difference between the Q9650 and i3 2100 is surprisingly small (although it will get bigger by overclocking the Q9650)
http://www.anandtech.com/bench/Product/289?vs=49
*edit*
you could always sell on the current motherboard, RAM and processor to cope with the tiny overspend, or get 8GB RAM
also, i forgot to mention, all socket 1155 motherboards do not support IDE hard drives or DVD drives, so you will need adapters if you were planning on recycling any IDE things. a PCI IDE card can be found on the interweb for less than £10 and has two IDE slots
this is the full spec currently
cooler master stacker (original model)
cooler master 1000w modular psu
asus rampage formula x48 (ddr2) mobo skt 775
core 2 e6600 2.4ghz
4x 1gb ocz ddr2 ram
bfg 8800gtx
2x dvdrw
1x xbox hd dvd rom
1x 74gb raptor + another 2 as spares - no spare sata ports for them
2 x samsung 1tb drives
2 x samsung 2tb drives
1 x wd 2tb drive
2x icy dock 5 bay hot swap drives.
1x 27" monitor
1x 24" monitor
razer tarantula keyboard/z-board
logitech mx revolution mouse/logitech mx 1000 mouse
i've liked the idea of an ssd but i would need an adapter to fit it into the hot swap bays.
You have lots of drives!
2 x SATA 6Gb/s connectors (SATA3_0~SATA3_1) supporting up to 2 SATA 6Gb/s devices
4 x SATA 3Gb/s connectors (SATA2_2~SATA2_5) supporting up to 4 SATA 3Gb/s devices
* The SATA2_5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip:
2 x SATA 6Gb/s connectors (GSATA3_6, GSATA3_7) supporting up to 2 SATA 6Gb/s devices
Support for SATA RAID 0 and RAID 1
I still think you will be better off with a quad core, and save to upgrade with ivybridge later, or save your money to get good kit (i7, good Z68 mobo, 8GB ram, SSD).
8GB can be useful fro development, as well as a SSD. But first the CPU I recon. You can put a decent cooler on it, which you can reuse later.
i think it probably is time to just try and save up and then refresh the main guts of the system. i can always get a decent mobo and then put an average/starter chip in for starters and then build up later.
If that would be the plan what would be the best thing to get? I have traditionally stuck with asus for my mobo needs are they still good or is there something better? As you say I have a lot of drives and truth be told i need more space for backup purposes. I am not going to try and burn this amount of info onto dvd's or even blu-rays.
