I got BT Vision a few months ago and have, right from the start, been frustrated by the terrible box. I've been using pvrs for many years, my favourite manufacture is Humax, fwiw.
BT box good points:
The padding where it will pad programmes that start one after the other on the same channel - the box will pad either side of both programs.
Maybe access to iplayer/4od etc (maybe - it's not that good a feature)
BT box bad points: - here goes:
Terrible remote reception - point the remote at anything other than the box and it might work - point it directly at the box, and it wont.
Doesn't work well with aftermarket/replacement remotes - I have a Logitech Harmony One remote that has, up until now, worked with every single item I have programmed it to. Not with this box though.
Sluggish remote response - when fast-fowarding through adverts and pressing play to resume, a lottery ensues as to the replay point. It might be 12 seconds after the point when you press play, or 1 minute before you pressed play.
Bad reception? I constantly get messages about poor/low freeview signal via this box, however, the two other pvrs (both dual tuner) and dtv never have any problems with signal - they all report a signal strength and quality of 10/10.
Menu. Who designed the menu? Imagine a list of 10 things. On every other single item I have ever owned, if I'm at the top menu item and I want the bottom menu item, I simply press the 'up' button to scroll from the top directly to the bottom. It's not rocket science, surely? Not on this box. To get to the bottom you have to press 'down' several times - this is made all the more difficult due to the FACT that this box is terrible with remote reception. This is the worst thing about the menu system, but the rest is equally unintuitive. Getting into menu options is incredibly frustrating.
Constant hanging - I'm finding that this box needs more resets than most others I have owned - kind of interrupts your viewing, no?
Sound - the sound stage constantly distorts, calling for a rewind to reset the sound. The box is connected via SP/Dif to my DSPAX640SETII amp that works fine with all the other connected equipment.
Apart from that, it's great. Not. Philips/Pace suck hairy balls.
What would be a good pvr (poss HD) - Humax?
BT box good points:
Is it any better now (not that it matters if it's a cable option only)?
