- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
Today Only we have 25 units of the Zalman Z9 Plus Tower Case with Fan Controller - Black for just £46.98inc VAT saving over £13!!
We also have (again) 25 units of the Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) for just £89.99inc VAT saving £18 on Old price!
** Yes I know there F4 is back on again but due to a small technical glitch I had to think fast
Zalman Z9 Plus Tower Case with Fan Controller - Black @ £46.98 inc VAT
The latest offering from Zalman is the Z9 Plus which offers amazing value and great features. This chassis is a must for any new build. Regulating your interior temperature has never been so simple: as the Z9 Plus includes a built in fan controller and LED temperature sensor allowing you to fine tune your cooling. The Z9 comes equipped with a well designed side window to showcase all your components and allow further cooling with its semi-mesh design.
- Motherboard tray cut out for easy CPU backplate removal
- Dimensions: 207 x 464 x 504mm (W x H x D)
- 3 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- 1 x 2.5" Drive Bay
- Expansion Slots: 7
- Space for 290mm Graphics Cards
- Front I/O Ports: USB2.0 x 4 / 2 x Audio / Fan Controller / Temperature display
- Front Cooling: 120mm /140mm fan x 1 (120mm Blue LED fan x 1 standard)
- Top Cooling: 120mm /140mm fan x 2 (120mm Blue LED fan x 1 standard)
- Bottom Cooling: 120mm /140mm fan x 1 (optional)
- Rear Cooling: 120mm fan x 1 (included)
- Side Cooling: 120mm fan x 2 (120mm Blue LED fan x 1 included)
Was £59.99 Inc. VAT
Only £46.98 inc VAT.
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £89.99 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
Was £107.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Was £59.99 Inc. VAT
ORDER NOW
- Capacity: 2TB
- Cache: 32MB
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
ORDER NOW
