List of Corsair H100 Compatible Cases
10 Nov 2008
Isle Of Wight, UK
Good day all.
I am looking at moving away from air cooling and going over to closed loop water cooling.
Can anyone tell me if there is a list anywhere of cases that are compatible with the Corsair H100?
The rest of my system is as follows.
Intel Core i7 2600K.
Asus Sabertooth P67 R3.
8GB (2x4Gb) CMZ8GX3M2A1600C8 XMP
AMD Radeon HD 6900
860w Cooler Master Silent Pro
I have upto £150 to spend on a case inc postage.
Can you please advice.
Thanks for your time.
I can think of these,
Coolermaster HAFX
Coolermaster ATCS840
Corsair 400R
Corsair 500R
Corsair 650D
Xigmatek Elysium
Doubt that does help much to be honest as the H100 radiator won't reach to a lot of cases positions for radiators. Doubt it will reach the front or bottom of most cases. So as long as the case can fit a 240 radiator in either the top or back it should be ok
