Help spec my new build
ok, I take it there is no performance difference? Also is it worth getting 16GB and would having 16GB affect me wanting to overclock the 2500k?
At 1600Mhz you won't notice any real difference between the different choices of RAM - I suggest you go for a LP type such as hyperX or the XMS3 as this'll leave more space for the cooler.
If you can afford 16GB, then sure - Why not max out the mobo if you can? Means no future upgrading so that's good.
thanks,
Getting 16GB would max out the mobo using all 4 slots. Would the xms3 run quad channel if i got 2 lots or can only the hyperX run quad channel? Not that i know the difference between how dual and quad channel work...(sorry really know nothing about RAM!)
thanks,
It will be still dual channel, just two banks of ram per channel.
Thanks, I think am sorted on my spec now :)
Cheers for all the help, I will post pics of the build over the next week or 2 :)
Final spec is:
+ My Crucial M4 128GB SSD that I already have.
