Best Rad for 1000rpm fans?
19 Oct 2002
Hi Folks,
Trying to tap in to the vast knowledge here to figure out the best RAD for about 1000rpm fans.
I'm looking for a 360mm.
I'm thinking the auacomputer Airplex revolution 360/420. Should be able to get it in the roof of my HAF932.
Any other suggestions though?
Still don't know which rad lol they all seem to have their pro's and con's.
I want something that will perform well at 600-800RPM but if i need to do some benching i can turn the fans up to 1900 to give better cooling.
My main objective is to make my rig almost silent (if possible)
Maybe the RX?
I was in your shoes a couple of weeks ago!
Have you looked at the XTX series from EK? I nabbed a 480 XTX the other day for my new project.
Yes i did they seem to be a good all round performer but are still beaten by the sr1-480 sub 800RPM
I'm really stuck if anyone can chip in
ek 480 xtx or the black ice sr-1 480
Aquacomputer airplex Revolution
It's a brilliant performer and often over looked, came out top in skinee's rad testing.
eZUz
http://skinneelabs.com/ac-airplex-revo/
http://skinneelabs.com/2011-2012-radiator-comparison/
Yes I think the airplex revolution is the one to go for but what 140mm fans would you pair it with?
Would go for SGT's but they are only 120mm and I will need to use the 120mm side of the rad to mate with the top of my case to fit it.
So have to go with 140mm fans....
noiseblockers? Want to stay low RPM 800-1000rpm I am trying to go silent.
