Just got back from a short ride in the sun.
Was riding down a country lane and it was slightly muddy, I guess. Anyway, all of a sudden, upon descending a hill, there was a strange noise coming from the back wheel. It was quite loud and sounded like the wheel had picked up a twig or some stones and they hit the mudguard or something. The sound stopped. I carried on riding for a bit and it came back so I pulled over.
I rocked the bike back and forth and narrowed the noise down to definitely being around the back wheel. It sounded like a creaking noise, as if metal was being stretched, so I checked the chain wasn't too tight and it was fine. I then realised it only happened when the bike was moving forwards. I looked at the back brake and couldn't see anything wrong. I checked all around the wheel and there was nothing that stuck out or looked suspicious.
I got back on the bike and rode slowly a few yards listening carefully. I then started applying the back brake stiffly to check it was working properly. As far as I could tell, it was. Anyway this got rid of the noise so I presumed it must have been some muck between the brake pads and the discs so I rode home.
When I got home I rocked the bike back and forwards again and there was a different noise that I've never noticed before. It sounds like rubber catching on something and it happens which ever way the back wheel is turning. There is nothing catching the tyre and the wheel spins freely as far as I can tell. I checked the chain wasn't just rubbing on something and couldn't find anything.
I'm lost, any ideas please? Thanks in advance.
